A/C Question, plz help.
Old 10-10-2007, 05:09 PM
bdford's Avatar
Default A/C Question, plz help.
Well, apparently My ac isn't working. The compressor runs like it should, it is holding a refrigerant charge, the fuse isn't blown and the fan runs but it wont blow cold air. The only thing i can think of is a faulty relay. Can someone help please.
-Brian
Old 10-16-2007, 10:09 PM
tommytwo's Avatar
Default A/C Relay
I had the same problem, and it was the A/C Relay. Good Luck!
Old 10-17-2007, 01:54 AM
rocket22's Avatar
try the low pressure switch
Old 10-17-2007, 03:38 AM
bww3588's Avatar
if it were either of these, the compressor wouldnt run.
its a mode door stuck open letting the air across the heater core.
