Orange fluid leak/water pump?
I noticed a little orange fluid on my garage floor today. It looks like Dexcool. After looking under the car I noticed a little of it on the sway bar and resting on the area behind my ASP pulley. Is this coming from the water pump weep hole? Or is my gasket just shot? It seems to only leak when it's hot, and I hear no water pump noise. It is the orginal (64,000 mile) water pump. Not sure if the gasket was replaced after the last cam swap either. I checked all the hoses and the radiator and noticed no leaks. The only fluid I see is where I mentioned. Any help would be great before I go ahead and change the water pump out.
Thanks!
Thanks!
I can swap my 160 T stat out with the one that will come on the new pump w/o any issues right?
Don't waste your time changing gaskets only. The gasket that needs changed it inside the water pump and as a general rule you should never try to rebuild a water pump....it will just leak worse when you put it back in.
1 Post
If you want to verify that it's coming from the water pump you'll have to get under it with at powerful flashlight while it's running and up to temp (pressurized). Follow the leaks and drips back to the source. For me it was easy as it was a HUGE leak.
Chances are good that the gasket will be FUBARed when you take off the water pump anyway. Use the gasket that comes with the kit. I got a standard replacement pump at the parts store and it's been working just fine for the last year or so.
BTW, that gasket was the hardest sumbich to get off I've ever seen.
Thanks for the replys guys.
Here is what I have found. It only leaks when the thing is hot. I cleaned the puddle up, it sat all night, barely a drip. Then I started it up, let it idle for maybe 15 minutes. When I checked under it a few hours later there was a little fluid. Now correct me if I'm wrong, but if the pump was bad wouldn't it make noise or leak 24/7???? After speaking to a buddy about it, he seems pretty sure it is the gasket due to shrinkage when it gets hot. Also, I did two cam swaps last year, not sure if a new gasket was put on the second time. So the gasket seems like it might be the issue? What do you all think?
Thanks!
Thanks!
1 Post
Water pumps leak from the shaft seal, and leak through the weep hole. You may/may not be able to see the weep hole. I got close but could not eyeball it precisely.
The water pump leaks when the system is at temp and PRESSURIZED. Mine didn't make a peep. No squeal. No nuthin'. Just a leak when at temp.
Expect a water pump change, but since you did your own work previously who's to say.
1 Post
Mine puked for the last time while in the Wal-Mart parking lot, which was fortunate since I could walk back in and get a gallon of A-Fr to investigate with. Wound up getting it flatbedded home for the transplant.
The one bright spot in it all was that a FINE looking redhead with a REAL short skirt parked across from me while this was going on (in a Camaro) and dropped her keys.
Do the pumps not always leak? Seems like mine leaked that one time that I saw, not agian since? Maybe I just cought it early? Do these things once they start to leak not do it all the time? Just seems weird....
depends whether you want to control the condition or drive it until it goes out completely and hope your are not too far away from home. I have been tempting fate for too Long, mine has the same problem.
Somebody correct me if I'm wrong but if its leaking from the gasket between the pump and the block then the pump has to be bad. There is not supposed to be any fluid there at all. The gasket there to prevent metal on metal contact.
