Help with Misfire
Help with Misfire
My camaro was driving fine before I changed all my plugs and when I took a test drive the car bogs and #7 cyl is showing misfire on my EFILive. I thought it might be the wires and/or coil so I swap both coil and wire with #1 and went for another test drive and #7 still shows misfire. Is there anything I've missed? Could it be the injectors? or a faulty plug??? anyone experience this before? Any help would be greatly appricated. Thanks!
oh i'm using NGK TR55 for plugs
Yeah. I'll go buy another plug tomorrow. Does bad plug happen often? I never heard of a bad new plug before. Weird. I'll post the result of my findings tomorrow. Thanks for your response.
alright.. it's the update...
I went to Kragen and bought another (1) NGK TR55 and replaced it. The car purrs smooth and seem like everything runs perfectly. No hessitation or anything. I just have to double check everything with my EFI Live. I'm so pissed that one "NEW" spark plug was faulty. Anyone know how to check the sparkplug before installing to make sure it's good. Cant trust new sparkplugs anymore. I'm sure it's not installation error because #7 is by no means hard to get to and I can do that one spark plug in 5 mins... anyways thanks SPARKY for the suggestion... You guessed the problem on the first try.
