car wont start fuel pump not kicking on
car wont start fuel pump not coming on PCM not getting power
MY 98 Z wont start, car had been sitting for a while but started up fine then died like 15 min later, fuel pump kept shutting off then after about 5-10 min it would start again. (I just put a walbro 255 in it 4 months ago). Also the relays in the fuse box sounded like they were goin a lil nuts lept clicking well now I decide to finally see about getting this taken care of and the damn thing wont start so I switced out the relays under the hood and tried another fuel pump, even tried my other set of keys nothing relays arent making the noise they usually do, pump not kicking on all...connections are tight. even double checked all the wiring on the pump itself. Only other thing I noticed is I have a hypertech programmer for the car I wanted to scan for any codes so I went to check and it kept saying "turn key to run position" even though it was in the run position, usually when you do that it goes to the next screen........could this be a problem with wiring in the colom maybe? Maybe a wire came loose or something in there thats why the programmer thinks the key isnt turned to "Run position" and the pump aint kickin on? The chime still comes on and all the lights on the dash come on though so I'm lost, The motor does crank just no fuel I can hear the pump clear as day I know 100% thats why it wont start just FYI to keep from getting off topic. Anyone have any answers??
Last edited by HottLS1Z; 12-16-2007 at 02:55 PM. Reason: new problem, additional information
does the pump at least energize for 2-3 seconds when you first click the key on? If youhold a test light on the relay and have someone turn the key the test light should come on for a few seconds.
I did a cliff notes and missed that point. Jack the car up disconnect the electrical connector to the pump. Take a test light and put it on the gray wire and have someone turn on the key. The gray wire should have 12v for a few seconds and then go out. Then have them try and crank it and see if it lights. If it does then check the ground wire heavier gauge black wire for a good ground. If that all checks fine the new fuel pump is junk. Have had that happen more than once. Even with gm if that is what you replaced it with. Check to see if the service engine soon light comes on when you turn on the key. IF it does the ignition switch is fine. Grab a scanner and energize the fuel pump relay and go from there if the above diagnostics fail.
Also If the ign switch is bad why would the dash lights come on (minus the SES light) and the car still tries to crank over? If the ign switch was bad the car wouldnt crank would it?
No SES and no fuel pump sounds like the pcm is not getting power. In the fuel pump relay there is one wire that is hot all of the time this is the wire that bridges over and powers the fuel pump when the relay closes. Check all of the fuses in the under hood power center with a test light, then with a multimeter to see how much voltage is present with the key on. Check the pcm a, b, eng sen, and others those are all I can remeber off of the top of my head. If those have no power or low voltage then pull the Pcm ignition power relay and jumper pin 87,and 30 this will supply power directly to all of the above circuits. If the pcm and fuel pump comes on then it is either a defective relay or a problem in the ign circuit that closes the relay to energize all of the components.
Thanks
I am betting money on the ign relay that I mentioned earlier. Take a few minutes and go back and read it a little closer in the post before this one. It is a different relay than the fuel pump relay. No spark and no ses screams that the coils and pcm are not getting power. To confirm this suspicion check to see if there is power on the pink wire at the coil main connector and check the pink wire at any one of the fuel injectors.
Well, got ir running, the computer wasnt getting power ran a hot wire to it with a switch so if the switch is on the car starts, if you shut the car off with the ignition it stays running! gotta kill the power to the computer for the car to shut off, any ideas why the pcm would not be getting power?
ok I we can try that but dont think ill be able to do that until this weekend unless plans change, this weeks gonna be a busy one, but on a side note I mentioned that switch we ran to get power to the pcm...well today the car decided it will start and run fine and shut off just by using the key with the switch off....like nothings wrong so it would appear whatever the problem it gone for now, not sure how to track this now that its not acting up...
