Front Turn Signal Light
Old 02-09-2008, 10:41 AM
tommytwo's Avatar
Arrow Front Turn Signal Light
How do you get the front turn signal light bulb out to change it? I tired to reach under the front grill, I can touch it but I can't get it to twist out. I tried to turn left and than to the right. How do the piece that hold the bulb come out? I don't want to go to a dealership to have a light bulb changed. Thanks in advance.
Old 02-09-2008, 12:59 PM
joshp14's Avatar
There is a release tab on the side of the socket that must be pressed in while you turn it. If you arent familiar with how that socket works, pull a tail light out...they have the same type of release socket...this will allow you to get a better look at how it works.
Old 02-09-2008, 02:21 PM
newton's Avatar
Did you remove the headlight? Makes everything easier.
Old 02-09-2008, 02:52 PM
RooRnZ28's Avatar
**** just remove the whole bumper.... that is much easier than jamming your hand in there and trying not to drop the bulb somewhere
Old 02-09-2008, 05:15 PM
tommytwo's Avatar
Thanks for the information.
Old 02-09-2008, 05:16 PM
tommytwo's Avatar
No I didn't, thanks for the information.
Old 02-09-2008, 05:17 PM
tommytwo's Avatar
lol....... thanks for the information.
Old 02-09-2008, 06:40 PM
Arrison24's Avatar
for a trans am just reach ur hand through the hole under the lights, reach up and you should be able to feel what hols the bulb. twist it out and change the bulb, very simple. for a formula, i have no idea i have a trans am
Old 02-09-2008, 06:45 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
CHECK SEARCH..THIS IS 1,000,000 times we have talked about it.
Old 02-10-2008, 01:27 PM
tommytwo's Avatar
Thanks, I got it out and changed the bulb and it didn't work. The connector had a lot of rust, so I guess I have to replace it.
Old 02-11-2008, 06:15 AM
qwk93ta's Avatar
This is how I did it over the weekend. I have a 00 WS6.
