Car has hard time starting
Old 04-26-2008, 12:32 AM
Mean87SS's Avatar
Default Car has hard time starting
I have a 98 LS1 Camaro...
It has a hard time starting, it will crank no problem, after about 5 seconds, it will start... or if I crank it, turn the key back then recrank it it'll start up...
Any ideas on what it might be? Mods in sig..
Thanks!
Old 04-26-2008, 02:21 PM
MJK
MJK's Avatar
Had a similar problem on a 1998 TA.Turned out to be the fuel pump.
You might want to (if you haven't already) make sure your car has had a decent tune up.That way you can eliminate all the obvious/simple problems.Plugs,wires,fuel filter,good battery....etc
Good luck.
Old 04-26-2008, 03:20 PM
Mean87SS's Avatar
Just installed TR55's, MSD wires, new 02 sensors, battery is new... only thing I havent gotten around to yet is a fuel filter.
What pump should I go with? Planning a cam swap later this year
Old 05-01-2008, 04:39 PM
FL_BILL's Avatar
This could also be a faulty crank position sensor. I had one go bad on my 99 TA with only 12k miles on it. It will make the car slow to start.
Old 05-01-2008, 07:47 PM
SSNISTR's Avatar
I had the same issue, it was a bad ignition relay.
