Is a catback a driveway job?
I want to replace the crapola flowmaster from the previous owner with a new catback. Is that a driveway job or should I send it out for installation?
I am thinking of a Spintech. I had that system on my '96 and the sound was awsome.
I would say no. My step dad and put my Borla on my Z in the garage of jack stands. It took longer than it should have, but it only took a couple hours, you could def do it in the driveway unless you started real late and it got dark.
Absolutely. It would be a little more difficult if you were removing a stock setup, or if you were trying to protect the system you are removing. But in your case, no problems at all. Back up on some ramps, chock the fronts, and go to town.
What kind of Y are you using - stocker or aftermarket?
I didn't have enough ground clearance to install my gmmg in the driveway. I was able to get the old exhaust off but had to take it to a shop.
My jack stands are too big for my jack so it gave me problems.
