Low charging voltage
I just noticed aabout a week ago that my running voltage is only at about 13.5-13.8 or so, which is kind of low.
From what I know this means my alternator is ready to croack. But, my 98 z28 only has 73k.
Is there any other cause for this?
Or should I just swap out the alternator?
I had everything running BTW, I was logging with HPTuners and it said 13.x volts. I got out my meter and put it on the battery, and then from the terminal by the relay box to ground and it read 13.8 at all locations.
when the alternator is cold it will regulate at a higher voltage than when its hot
