Power Steering Leak!
ok it has a pretty slow leak. wat are common places that leak.. power steering pump? hoses? pressure or return?.. the boot on the rack n pinion thingy is pretty dirty..
its a 99 camaro z28 has about 88k
The most common places are the pressure line from the pump to the steering gear and the pump shaft seal behind the pulley. Its normal to have a film around the steering gear around the boot area and where the steering shaft goes in. If you have drips from the steering gear then that needs attention.
the driver side boot is leaking. i pulled it out and there was a ton of fluid in there. it looks like there should be a seal or some sort of O-RING between the center and a shaft that moves i guess. am i going to have to replace the whole rack and pinion? or do they sale a replacement seal?
