drivers window hitting triangular piece
Old 06-28-2008, 12:45 PM
fortmyerspolice's Avatar
Default drivers window hitting triangular piece
Like the topic says, I want to try and remove the triangle piece and move it further to the right so the door window can close easier.
How do I do it?
Old 06-28-2008, 01:16 PM
Pewterpower's Avatar
Is your door out of whack, or is that an optical illusion? Cuz it looks like its a good 1/2" lower than the door frame.
Old 06-28-2008, 01:19 PM
someone rear ended me and they had to replace the well, drivers quarter panel, bumper, and catback. The door wasn't touched I don't think.
The very right edge of the window comes in contact with that triangular piece.
Old 06-28-2008, 01:25 PM
There are a couple of adjustments you could make to the window track to try to get it past that. But then you run the risk of misaligning it at the top. Do you have any leaks at the T-top seal? I think the root of your problem is the door not lining up properly.
Back to your original question, though. I'm not sure how that triangle is attached. Probably glued.
Old 06-28-2008, 01:27 PM
Both of my t-tops leak on both sides, don't know where the leaks are coming from though, they drip onto the sail panels below the speaker, pisses me off. If it's raining REALLY hard, sometimes I get a leak at the top of the window and on the rightmost edge where it's hitting that black piece.
Old 06-28-2008, 05:45 PM
gnomee's Avatar
Did the body shop straighten the frame? If you got hit hard enough for your door to bee like that I would say your body is tweaked and they should have put it on the frame straightener.
Either way take it back its not fixed if everything is not back the way it was before you where hit.
Old 06-29-2008, 12:30 AM
It is, it didn't hit THAT hard. The door closes fine I just need to move that triangle piece over a bit more.
Old 06-29-2008, 09:51 AM
Weezzer's Avatar
Your not getting it - pay attention. ITS NOT THE TRIANGLE PIECE, your door is out of alignment. And if its on both sides of the car then the frame is more than likely OUT OF ALIGNMENT!
Lets try this: You can move the triangle piece to the right by straightening the frame back to specs.
Take it back to the shop.
Old 06-29-2008, 10:17 AM
I can't take it back to the shop. Car was hit in april of 07. I went out and looked at it today, the door is a little out of alignment but nothing crazy, not caused by the collision but from being used too much. Even so, I can lift the door a little bit when I close and it makes very little difference. It barely hit's the peak of that little triangle piece. I JUST want to know how people take this stupid thing off, because someone didn't put it on right. The door closes with little force with the windows down also.
Old 06-29-2008, 10:22 AM
Viper's Avatar
LS1Tech 20 Year Member
It's glued on. Pry it gently with a thin flat screwdriver and reapply.
What kind of glue should I use?
Old 06-29-2008, 03:57 PM
98 WS6's Avatar
Idk about the glue, maybe any crazy glue, you just gotta make sure you put it on clean. Does your door somewhat wobble up and down? If so your pins may be shot but I doubt it. Either that or your frame really is messed up..
Old 06-29-2008, 09:15 PM
sneaky7980's Avatar
Is the pic you posted of the door completely closed?
I've gotta agree with the above, i've had and worked on more than a few 4th gen f-bodies and i'd say most likely your unibody is tweaked. The leaks you listed would most definetly be a result.
You need to find the root of your problem, and i don't think its the triangel panel. THose things seldom act up...
If all else fails, do a search for "window alignment write up" under my name and see if that helps you out.
good luck!
Old 06-29-2008, 09:17 PM
The door isn't closed in the pic. The door lines up fine when it's closed.
Old 06-29-2008, 09:21 PM
Here's a pic with it closed.
Old 06-29-2008, 10:11 PM
2002_Z28_Six_Speed's Avatar
That isn't that bad. You need to pull the door panel off and adjust the window. Move the window glass forward.
Also check your window stabilizer pins. They may be broken from the impact of the crash. Do your windows feel sloppy and loose?
There is alot of adjustment to be had with the windows, t top molding, you name it.
Old 06-29-2008, 10:38 PM
The black window plastic piece keeps popping off too like it is in the pic but I can pop it back in, it always keeps popping out though. My windows don't feel sloppy, at least I don't think. GM dealership replaced the window motor about 1 year ago. Also, everytime I close the door with the window down, it sounds like the window rattles. My passenger window also rattles barely when the window is down.
My door panel is cracked and is sort of gouging into the window, which I'm sure is not helping.
Old 06-30-2008, 06:39 PM
I would pull the door panel and see if your stabilizer pins are broken. The window shouldn't rattle.
Old 06-30-2008, 06:58 PM
I don't know what those look like, where they are.
Old 06-30-2008, 09:33 PM
Here are some pics complements of SHBOX.COM
You CAN NOT see in the pins in this picture. The pins are small white pieces of plastic that stick up through these stabilizers. Their purpose is to stop the window from being fluttery. They firmly lock the window into the door frame instead of floating around on the tracks. This stops weird noise. Not being firm. Ect.
