Removing door panel in a trans am
I have a 94 TA... I assume 93+ have a pretty similar door panel but I could be wrong. I'm trying to use the pictoral for removing a door panel but the pictoral is based on a camaro and looks completely different from my door panel. Are there picture instructions for taking off the door panel for a firebird/TA anywhere?
Copy & Paste Moderator
Took like an hour for me to get the door panel off. A lot of the time was spent lookin for different screwdrivers and wrenches :o
The worst part were the nuts/bolts holding the motor to the bracket. Someone had already drilled the rivets out, but the bolts that were in there were bolted and were a PITA to get out. Took us probably over an hour to get those 3 loose... it was crazy. They were crazy overtightened and didn't want to come out, we had to pry at em for ages. It also took me 30 minutes to get the motor aligned correctly, no idea why.
I have a feeling my other door will probably take me <1.5 hours. The worst part will be the bolts again if they're the same as the other side.
