Motor mounts going?
Motor mounts going?
Currently at 165k miles and I've noticed that when in 1st or 2nd gear and I give it some throttle, there would be a slight delay in throttle response caused by a torque "thump" or "kick". It isn't a real hard kick, but noticeable.
Is this a sign for bad motor mounts?
1 Post
motor mounts would be an excellent upgrade in that situation, i know my motor mounts were cracked at 86k u can also try upgradeing to poly torque arm bushing and poly tranny mount and then the motor mounts
To check for a bad motor mount open the hood and look at the engine through the windshield while you power brake it for a second. If the engine lifts a lot, or twists they are bad.
How difficult is it to install poly motor mounts?
I've read here that if you don't add poly motor mount after you added poly to the trans mount you can break some part of the transmission?
1 Post
that is still not so accurate, when i free reved b4 the motor mounts the motor moved some, the stock mounts are junk, the prothane mounts i put in are twice the size of the stock which is more surface space and more rubber
1 Post
thats not true, i had my poly tranny mount for about 6 months or more b4 i did the motor mounts, i can see that happening maybe if one of the motor mounts were completly broken and there was excessive play.
It's either test like I said or just throw some new ones of some type on. Still not knowing if it's a motor mount problem but what the hell just throw parts at it, one day it'll work right.
1 Post
^^^ go under ur car and take a good look at ur drivers side motor mount, push on it with ur finger, mine felt soft some will be mushy. whatever the drivers side is the passenger would be 2x worse since the engine moves to the passenger side from torque.
When you visually check motor mounts you look at the bolt, it should be in the center of the shell or close to the center of it.
