throttle body gasket question
So i took off the air intake throttle body and theirs a gasket between that and the plenum. can i just use rtv gasket maker or do i need a new gasket? I dont want to get a new gasket yet because im going to take it all apart soon, so that why im asking this dumb question.
I wouldn't do it with RTV. Is the gasket torn? If you didnt tear the gasket I would try to reuse it. After you get it all bolted back together spray throttle body cleaner or brake cleaner around where the throttle body mounts to the intake. If the engine stays running a constant speed, your good to go.
