pcv setup, i think i have it setup wrong
ok guys, i have been battling issues with my swap car, but i ran across something (the pcv setup) I have a revxtreme catch can coming in the mail, but is the pcv valve coming directly out of the drivers side valve cover in that grommet.
thats how i have it setup, if not how do i need to correct this.
With the LS1 PCV system the rear tube on the P/S vavle cover and the opening on the rear of the D/S valve cover (the one you are refering to) actually Y together via a rubber connector at the rear of the engine. A single tube then runs up the P/S between the valve cover and the intake to a nipple on the front of the intake.
I am not familure with that catch can but isn't there a valve built in to it? If so the single line that runs to the intake would run through the can and then to the intake.
Ya, you would want the valve after the merge of both lines.
You could do this:
You can basically make your own PCV system out of 3/8" rubber fuel line a "Y" fitting and a 90* elbow that would be inserted in the D/S valve cover (an elbow as you described). You would need to be able to connect the PCV valve some how if you don't have the rubber case for it. The nipple end of the valve would point towards the intake (vacuum source).
Or this:
You could spend around $80 and change out the valley plate for the 2004+ LS1/6 valley plated. The nipple on the plate is very close to the intake location and requires a short "U" shaped hose for a connection. This new plate contains the PCV system and orafice (replaces the valve) all together. Other than just replacing the old plate you may have to, unless you have an LS6 block, notch out a location in the valley that is not very hard to do (I did mine).
You could do this:
Or this:
i mean i have the pcv hose capped off, as i have the y setup, (from the 98, my 99+ valve covers dont have that insert) so i put a vacuum cap on that piece and put a worm gear on it and called it a day.
my valve cover looks like this with only one port on it towards the front;
http://cgi.ebay.com/ebaymotors/4-8-5...spagenameZWDVW
I am basing what I know off my car. This is the P/S valve cover and I see the inlet tube that connects to the TB near the oil fill. There should also be a tube towards the rear (and facing rearward) of the cover also for the PCV. It would be on the side like the inlet tube. I can't see it in the picture.
With that said and if this is what you have I would look at doing something about the situation. Short term I would think it will be fine but over the long run you don't have an adequate way of venting your engine of it's impurities (for lack of a better word) and damage seals. I guess you could change the valve cover to one with the additional tube or go with a LS6 valley cover and scrap the old PCV system.
That is the location (back of both valve covers) on the stock LS1 PCV system's. The valley cover's (that I spoke of earlier) has the outlet for the PCV system near the front of the intake. Having the PCV drawing from the valley opposed to the valve covers works better and is why GM updated its system.
correct, i have the old system, noway i can change it (now atleast). my question, is can i pull the pcv vlave from the drivers side valve cover(replace with elbow), since i will have the pcv valve in the catch can now?
