exhaust question
exhaust question
im a little new to the ls1 thing but im wondering is there anyone out that makes a off road y pipe to fit and retain the factory exhaust manifolds. just wondering if a yes or no.. if not then what would be some good headers to go with not costly and a ory as well. and it has a slp catback already to.
There are a couple, bassani is one of them i know that makes a y-pipe that bolts up to your stock manifolds getting rid of you cats. But if your wanting a headers Pacesetter, edelbrock, and BBK all have headers with ORY in the $500 range.
SLP makes an off road y pipe that will connect directly to your factory manifolds.
http://www.slponline.com/view_product.asp?P=31035 $199 bucks
If you dont plan on doing headers at all this may be ok If you have the newer cast Manifolds, But if you have the older ones I wouldn't waste your time. Buy a set of cheap headers and ypipe, you will be much happier.
