help with heads
help with heads
I'm looking for a good set of heads, I've installed a Lunati Voodo camshaft
113 degree lobe seraration
212/213 duration
.312 intake lobe lift
lift at valve(thanks to previously installed 1.85 rockers) is .578
What do you guys think?
212/213 duration
I am guessing this is a SBC 350 or something? That's a pretty mild cam from what I can tell. Sort of like an RV cam. IF this is all the case, I used to have an old truck with a Lunati cam that was a little bigger than the one that is mentioned above, and I have some world products sportsman heads. Worked great. Ran a 12.2 in a 4500lb truck on a 150 shot of nitrous.
Damn I was confused because of the size of that cam. That's barely bigger than the stock LS2 cam. You could go with 243 castings and see a pick up in power. Definately wouldn't have to spend a ton of money for sure.
