Engine running bad after header install/egr delete
Old Oct 26, 2008 | 07:49 PM
Fast98Z's Avatar
Default Engine running bad after header install/egr delete
Installed headers, took out all EGR. Got the code 0405 which is "Exhaust Gas Recirculation Position Sensor Ci" Cleared it with tuner. My car is loping to the point where it olmost dies then will rev to about 1800 and back an forth... is there something i did wrong with taking out the EGR? would that cause this to happen? I took out all the hoses, left the actual EGR motor or whatever it is in the car but i disconnected all the wires going to it. Any help is appreciated, thanks. I had also replaced all the spark plugs if that helps with anything
Old Oct 26, 2008 | 09:12 PM
jrpimp00's Avatar
I did mine last week, header install, LS6 intake, !EGR, !AIR. Put over 80 miles on it still no codes, sorry. I just taped the conector up out of the way.
Old Oct 27, 2008 | 06:41 PM
Fast98Z's Avatar
just realized that when i put my spark plugs in, i didnt set the spark plug gap and just threw them in could this be the reason the engine is idleing up and down?... the engine did die a few times
Old Oct 27, 2008 | 08:01 PM
2K2WS6TA's Avatar
That could be the cause, also check the wires did they click when you installed them on the plugs and the coils
Also check the plug that you put in the intake to plug up the EGR hole (you did put one in didn't you) there might be a vacumm leak there
Old Oct 27, 2008 | 08:05 PM
ttranssam's Avatar
yea plug in the wires...
Old Oct 27, 2008 | 08:09 PM
JTelesone's Avatar
or you could possibly have your 02's backwards or not completely screwed in
Old Oct 27, 2008 | 11:13 PM
Fast98Z's Avatar
Wires are all clicked in, EGR seal on TB is tight, o2's are correct... i will be pulling the plugs out tomorrow and going to set them at 0.40. My buddy had picked them up for me while he was at the local auto parts store, and failed to mention that the guy had told him they needed to be set to that. I even saw the writing that he put on the box and it didnt even click to me. Thanks for all the input, will let you know how it goes.
Old Oct 27, 2008 | 11:18 PM
snake charmer's Avatar
i was thinking spark plugs . sometimes there are small cracks from not being handled right during the shipping and storage process . that or the gaps or not the same .
