part number/ funtion help please
I was getting pissed off and should have walked away but didnt and ended up braking a part it is a lil black box comming off of one of the fuel lines it has delphi 1997278 written on one side and 7239-8 on the other side I am afriad to start the car without it being replaced
Yes.. it is the purge Valve/Solenoid..
Not much will happen as long as the line to the tank is open... With the hose connected to the valve.. the solenoid will close the valve and seal the tank from vapor escaping.. the PCM will activate the solenoid and allow manifold vacuum to purge the tank of the vapor..
right now.. all of the vapor from the tank are just escaping into the air... the hose is just acting as a vent.. but you should replace it..maybe just get one from the local junk yards for a few $$'s.. if you have the time, someone might sell you there if they are not using it..
search the online stores.. and you will find it under purge valve..
here..
http://www.partsamerica.com/ProductD...pe=760&PTSet=A
Select the link to see all vehicles that fits... it is used on many GM vehicles of the same years.
But for $24.00 or so.. you can also buy one...
good hunting in the yards..
here..
thank ya for the help guys I just went up the parts store and ordered a new one. also while installing my wiend intake manifold I busted my oil sensor so I am just going to pull the heads order a cam and get the damn motor done so I stop usting up stupid ****. Tick Performance I will be caling monday I have a few tree huggers to **** off
