what size fernco w/ 85mm maf?
4.5" to 3"?
4" to 3"?
this is just because im lazy and don't want to go measure...maybe someone already knows off the top of their head...
4" to 3"?
Re: what size fernco w/ 85mm maf?
I have a 3" on mine with a stock MAF. The TB side had to be stretched a bit to fit. So I would get a 3.5" and a 3" and test fit to see what will work better. Note by putting it in the microwave for about30 to 45 seconds makes it very plyable. Just be careful cause when it comes out of the oven it will be hotter than hell! lol I almost burnt the **** out of my hand ( left it in for a full minute ).
Moderator
Funny thing. I had my SLP 85mm MAF off last night,
and I happened to look at the front coupler hose
that came with it... embossed on the end, Fernco
USA. But this is not yer Home Depot sewer hose
coupler, it's a thinner and shorter rubber piece
with hose clamp "keeper" ridges. End face marking
says "1059-33". On their site this shows up as a
very different-looking thing, a "Socket to Pipe"
connector with Side A at 100mm (4") and Side B at
89mm (3.5"). Maybe SLP just cuts off the fat end
and uses the 89mm end as the hose.
Yeah, I just looked and one end shows signs that
it is cut, while the other is virgin molded finish
so I think this is your baby.
The 89mm size is a bit nicer and a bit unusual,
no griefing on it or microwaving to make it fit.
I sent Fernco an email asking for info on how to
get this piece. I'll let ya know if I get an
answer.
answer.
