tsp tds hang to low
Buddy, I have had and installed a number of these systems. Good fitment is relative. Even with maximum clearance, it is still foreign to the underbody of these cars. It is a good bang for the buck off the shelf true dual system, but my statement holds true. The way to go is custom fabricated 2.5".
LS1Tech Premium Sponsor
Definately spending some extra time with the initial install will help a lot when it comes to clearance. If your not careful you can improperly install the duals & they will hang down way to low. Take you time & set the car up while weight is on the suspension. This will help to give you extra clearance like the car has when it drives down the road.
Jason
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
