tsp tds hang to low
Old Nov 21, 2008 | 07:15 PM
camaro468's Avatar
Default tsp tds hang to low
just installed lt headers and the tsp tds and they hang way to low at the dumps whin i say low i mean like 2 in off the ground i am thinking about going to a muffler shop and see what they can do couse that **** ant going to work way to low
Old Nov 21, 2008 | 07:37 PM
Pntbll309's Avatar
And the point to this post is?
Old Nov 21, 2008 | 07:46 PM
camaro468's Avatar
just seeing if anyone has any ideas maybe that i might have done something wrong or way to fix it
Old Nov 21, 2008 | 07:54 PM
mean_greenZ's Avatar
maybe extra hangers?? is your car lowered?
Old Nov 21, 2008 | 08:07 PM
camaro468's Avatar
nope ant lowered thats what gets me i have seen these on lots of cars and they are not that low
Old Nov 21, 2008 | 09:34 PM
Flaring Afro's Avatar
i've seen comparison pics. some they were tucked nicely, others like you described. no offense but it depends on install i have heard.
Old Nov 21, 2008 | 09:59 PM
gsxr1k2's Avatar
I just went through this with a buddys car last week. We first installed the duals with the rearend freely hanging which resulted in the torque arm being to low. All we did was jack up on the middle of the rearend and that gave us at least 3" more.
Old Nov 21, 2008 | 10:06 PM
camaro468's Avatar
yeah makes sence i am gona try to figure it out tomarrow
Old Nov 21, 2008 | 10:07 PM
camaro468's Avatar
i am gona try that tomarrow thanks for the info
Old Nov 22, 2008 | 06:23 AM
Raise's Avatar
This is gonna happen when you buy an off the shelf true dual system. The underbody of these cars werent made for a dual setup, which is why, for best clearance, people usually have an exhaust shop fabricate a setup. It usually isnt that much more expensive, if at all, and it will maximize your clearance. Good luck buddy
Old Nov 22, 2008 | 06:43 AM
SS4Luck's Avatar
undo your hangers, jack the TD's up from the merge until they are hitting/almost to the floor and then tighten hangers, i know it sounds retarded but it works wonders
Old Nov 22, 2008 | 01:02 PM
gsxr1k2's Avatar
Not hardly the case. When installed right they fit excellent.
Old Nov 22, 2008 | 01:30 PM
sixpack_2_go's Avatar
i changed the back of mine after the x-pipe and they dont hang any lower than my old y-pipe. i can go over speed bumps with no problems. take it to a shop and see what they can do.
Old Nov 22, 2008 | 02:04 PM
ss1's Avatar
ss1
Using a floor jack and block of wood works wonders. I gained a bunch of clearance on my exhaust by doing this and tightening up the clamps.
Old Nov 22, 2008 | 02:46 PM
Red96TA's Avatar
X2................. worked for me. Also the X merge only goes on one way. It doesnt look like thats the case, but it makes a big difference. On mine, it gave me like two inches extra. You might try flipping it over. GL
Old Nov 22, 2008 | 06:23 PM
camaro468's Avatar
i worked on it today and got them to tuck up a little better by useing a jack
Old Nov 22, 2008 | 07:21 PM
Full-Force's Avatar
Just what I figured. You have them upside down.
Take the rear pipes out of the x, flip it over and reinstall it. Keep all clamps loose until you have it all tucked as high as possible then tighten it all down.
If you notice the pipes coming out of your x have an angle to them. The angle is to position the rear section up to make up for the larger diameter of the mufflers.
Old Nov 22, 2008 | 07:38 PM
camaro468's Avatar
ok so your saying i still have it wrong that i have the pipes up side down comeing out of the x pipe right
Old Nov 22, 2008 | 07:41 PM
blkbird's Avatar
Im about to do this in the near future and dont want anything to hit..... my car is also lowered.......
Old Nov 22, 2008 | 08:16 PM
Full-Force's Avatar
in that pic the system is upside down from the x back.
