iron block alt mounting help!?!?!
I am in the process of putting a iron block in my car and noticed that the alt bracket doesn't fit. The block does not have the the hole drilled for the top bolt. I tried using a 2nd bracket from the back that i got off a GTO but that doesn't work either. I got this shortblock from a sponser and I am a little upset that this hole was not drilled and tapped before i got it.
How are you mounting your alt in your F body with a iron block? other than drilling and tapping the block.
Tyler
Tyler
I did this.....
https://ls1tech.com/forums/search.php
and came up with this
https://ls1tech.com/forums/generatio...lternator.html
lol. There was a better thread but i can't find it. I did copy the thread to a word doc though. I can email it to you if you want me to. It has pics and all.
I know the feeling. I was hoping to use the F-Body accessories on mine, but then found out I'd have to drill and tap a bolt hole. You must have one of the later castings, like i do. (04 yukon engine) That is the only way to get the bracket to bolt to the block that I know of.
