coolant crossover block offs?
i am looking for the part # for the square shaped block off deals that go on the cylinder heads,(2 on each side i believe)a number and or illustration would be great.they connect in with the small crossover tubes on top of the intake on an LS1.Thanks.
Look carefully ubove the timing cover see the tube that goes from one head to another that is the cross over http://mycarpics.shutterfly.com/198 If you can see them the little blocks that bolt in the head is what you get for the back. Also look to the left of the black plastis pole (oil pressure sensor) you'll see the plug for the rear of the heads.http://mycarpics.shutterfly.com/202
