?? on motor build
?? on motor build
I plan on building a 6.0 lq4. I want a motor that will revs to 7500 to 8000 RPM a day and not go boom and I want to make 600 to 700HP on motor if i can. What kind of a stroker kit should I look in to ( 377,383,400,406.and so on) and what heads and cam should I get to. The motor will go in to a 2gen RX7 any help would be nice.
thanks
thanks
Why is this in External?
Anyway, why do you want to rev so high? It's not going to help you any unless you have a cam that makes power that high.. and that usually means it's going to suffer down low...
The motor is going in to a rx7. I don't need low end TQ. That's why I want a motor to rev high the car is light. I have a buddy that has a 383 that rev to 7K in his RX7. So what would you guy do then to have a high RPM motor then?. When I had a lt1 in my FC. 1 and 2 gear was point less ever with good tires. But when I put the 306 cam in and some other goodies in and then power went for down low to in the middle and I had more top end so it was better then before.
