3" Duals
Old 01-02-2009, 09:02 PM
regency's Avatar
Default 3" Duals
I am making alot of changes to the truck right now and exhaust is one of them. I did some porting on a set of 243's i had laying around and milled them .010, also using some .040 cometics. I made the heads look as close as i could to a set of Patriot stg.2 LS6's i took some pics of.
I also have the 228R-112, Fast 90 mildly ported/LS2 TB, Underdrive Pulley, CAI, Pacesetter LT's
My exhaust at the moment consists of just comming off the headers (3" collector) with a 2.5" SBC collector reducer, back into a 2.5" dual in/dual out Magnaflow with built in X and regency tips welded to the muffler. Im thinking of going with 3" duals with x-pipe into the same muffler/tips combo!
Old 01-03-2009, 08:18 AM
Pharcyde50's Avatar
Running 3" duals here and love the sound. I'm getting ready to do a 3" true dual setup on my neighbors 2500 GMC.
Old 01-04-2009, 10:15 AM
regency's Avatar
anyone with experience with both 2.5" and 3" on the same setup
Old 01-04-2009, 11:15 AM
teke184's Avatar
with your mild setup, i can't imagine you'd gain much.
sound could change if you use different mufflers, but i can't see power changing significantly
Old 01-04-2009, 01:11 PM
regency's Avatar
well im not too worried about the sound changing. I would just like to maximize my current setup
Old 01-04-2009, 05:27 PM
teke184's Avatar
dual 2.5" pipes should handle the 450hp you're making at the crank....
i suppose its possible you would gain 2-3hp with 3" pipes....but is it really worth that much hassle?
Old 01-04-2009, 07:49 PM
regency's Avatar
no hassle!! i have LOTS of room under here
Old 01-04-2009, 07:53 PM
01ssreda4's Avatar
i would do it but why run the three inch duals and keep your 2 1/2 muffler?
Old 01-04-2009, 08:08 PM
regency's Avatar
i wouldnt! if i go with dual 3" im getting two Single in / Single out mufflers
Old 01-04-2009, 10:42 PM
01ssreda4's Avatar
sweet man i would do it. i mean you got plenty of room.
Old 01-04-2009, 10:46 PM
LS1-NAVY's Avatar
x pipe with borla xr-1's
