New Duals Soon
New Duals Soon
Just wanted to see what you guys think of my soon to have new dual setup.
Car is spring summer fun car so i dont care how loud it is, but ground clearance is an issue, going with 2.5 duals under the right side with 2 power packs and side dumps. i think this should sound aggressive as hell with no crossover and be pretty light, and once the cams in i should get plenty of tickets!!
pics and videos when completed
side exit and good ground clearance rarely go together.
dump them, or run them up over the axle and out the back.
and i would put some kind of crossover in. magnaflow makes a nice compact X pipe, the legs are parallel in/parallel out so its easy to put in a side-by-side pipe setup.
this setup has it...i would dump it after the mufflers if you want it light.
the duals on my old lt1 were like this but over the axle on the right side, i dont want that, its too heavy, also a crossover will cost more money and for the extra 5 horsepower i dont think its needed, the exhaust should tuck up like stock if he does it like my old car, then turndowns facing the side of the car, shouldnt even see it.
