what is needed when swapping LS1 intake with LS6?
ill be getting my LS6 intake this week, i have a 2000 WS6, i dont have EGR becuase of my longtubes, what all i do need for this thing to bolt right up?
ok well you either need to buy the ls6 coolant crossover tubes or shave all the ribs on the bottom of the intake. inspect the gaskets that come with it if they are damged buy new intake gaskets if not leave them. some choose to buy the oil sending unit ahead of time in case they break it but if your just careful you should be fine. a search will do you wonders there are a lot of threads on this...
You do not have to have the tubes, you can leave your ls1 tubes on and never touch them. On the bottom of the intake you will see ridges, take a grinder with a sanding wheel and knock the ridges off, dont get into the bottom of the intake just smooth it off. some people dont do this because they say it weakens it thats Bull crap. I have also heard people say they did not want to do it because of the way it looks,,,,,,, all I can say is if you can see the bottom of the intake on the car, I would like to know how you shrunk yourself that small. If you choose not to grind the ribs, you will have to buy LS6 crossover tubes, about $50.00 Other than that it is a direct bolt in. when you get it ready to come out LIFT THE THING UP BEFORE PULLING IT FORWARD, or else you will break your oil pressure sending unit. listen to me I broke mine, and it dont take much to break it, and thats another 40 bucks. hope this helps
no the LS6 coolant lines are not on the back of the intake. LS6 coolant line kit consist of the front coolant crossover tube and plugs for the rear
