Harland Sharp Non Adj Rockers
Old 01-26-2009, 08:52 PM
1badrz28's Avatar
Default Harland Sharp Non Adj Rockers
Do they fit under the factory valve covers with out hitting?
Thanks,
Old 01-26-2009, 09:07 PM
HavATampa's Avatar
Yes. I've been running them for a few years. I believe the '98 model engines with the perimeter bolt valve covers are the ones that rub.
Old 01-26-2009, 09:11 PM
1badrz28's Avatar
Thank you.
Old 01-26-2009, 10:14 PM
405HP_Z06's Avatar
It depends. We installed these on a 2003 Z06 and the heads and valve covers required clearancing. Not saying this will be the case for you, but don't be surprised if you have to clearance.
Old 01-27-2009, 07:07 AM
teke184's Avatar
mine cleared the valve covers no problem.
but i had to remove 1/16" of material from the inside edge of the valve cover gasket surface on the head to clear the top edge of the rocker.
it was nothing 5 mins with a hand file didn't take care of.
picture:
Old 01-27-2009, 10:18 AM
CriminiSS's Avatar
^^^^^^^ I had the same problem. again not a big deal at all though.
