Disabling fuel pressure regulator
Old 01-28-2009, 08:52 AM
radiowaves88's Avatar
Default Disabling fuel pressure regulator
I am using an LS1 in a street rod project and will be using a Mallory fuel pressure regulator on the frame rail. I'd like to use the stock fuel rails, so is there any way to disable the stock regulator? Thanks.
Old 01-28-2009, 08:59 AM
9000th01ss's Avatar
The stock regulator is in the gas tank. I don't know what the hell that thing on the fuel rail is but it can't be a regulator because there is no return line.
This is assuming you're not using an LS1 gas tank.
Old 01-28-2009, 09:21 AM
OK, I was assuming that the round piece that is held in by a snap ring on the fuel rail inlet was a regulator. If not, what is it? Thanks.
Old 01-28-2009, 10:26 AM
LS1MCSS's Avatar
It's a dampener to keep the fuel pressure from pulsing.
Old 01-28-2009, 11:54 AM
9000th01ss's Avatar
Thats what I thought actually, I didn't say anything because I didn't know for sure.
Old 01-28-2009, 01:10 PM
Oh sorry, I thought it was a regulatur. So I guess it's ok to leave it in place, right? Thanks for your help.
Old 01-29-2009, 02:07 AM
5.slow99's Avatar
Default fuel pressure regulator
look at it like a one way check valve pretty much allowing the fuel to cross from one side but not back to the other like stated above practically
