Dynatech Slip Fit Headers
are you looking for something to seal up between the slip connectors so they dont leak? idk if rtv would do the trick. one trick iv heard of is a little bit of axle grease. maybe put a little on the collectors before you slide the y pipe on. this stuff heats up and gets hard, creates a hard carbon steel. i think this is what ill do, unless someone has a better idea.
