What lid for 85mm maf and stock TB?
Old 04-06-2009, 11:17 PM
sman's Avatar
Default What lid for 85mm maf and stock TB?
Just finished putting an lm7 in my 99 v6 camaro. Im using the stock 85mm truck MAF (came with the motor) and the stock 78(or whatever it is) TB. On the v8 cars my understanding is that the maf goes in the end of the lid then a couplling to the TB? If so what size lid do I want? I know the ftp is actually bigger than 85.
Help me out guys!
Old 04-07-2009, 12:41 AM
Fast Toys Performance Parts's Avatar
Default Ft 85!
If you are using the 85mm Truck MAF the FT 85mm LID will allow the MAF to slide right in with no coupler required!
If you are just using a stock sized LS1 Fbody MAF, you can still use the FT lid but you need to purchase the adapter for 8.00 additional.
Cool swap!
Old 04-07-2009, 01:01 PM
sman's Avatar
Will the fast toys lid hit my ss hood, its an original off of an 02 SS?
Old 04-07-2009, 01:07 PM
It will probably rub just like other lids on the market. What we suggest is to put a piece of the soft velcro adhesive on the contact point where the lid touches the hood to prevent any paint rubbing.
Old 04-07-2009, 01:18 PM
sman's Avatar
This wont damage the lid at all?
Whats the cost on one of these bad boys?
Old 04-07-2009, 01:26 PM
No it is just a minor rubbing problem so it will not damage the lid. They are 146.99 shipped. If you need the coupler for a stock sized MAF, it is an additional 8.00
Thanks
Old 04-07-2009, 01:47 PM
01Z0H6's Avatar
This one...
Old 04-07-2009, 02:18 PM
shiv15's Avatar
spencer I got an ftp you can check it out tonight and we can talk about your intake setup. I've researched a fair bit lately on it
Old 04-07-2009, 05:42 PM
sman's Avatar
Thanks Andrew! See you in a bit!
