KOOKs header install drivers side WTF
I got the passenger side header on after pulling the starter off. These are kooks steped race header what do you have to take apart to get the drivers sided on heck I cant get it around the kmember stock and the oil pan.
please help
please help
When i did my 1 3/4" hookers, for the drivers side i tried unbolting the steering shaft to no avail. So i removed the bolt that goes through the motor mount and used a trans jack to lift the motor up like an inch or so by the oil pan, and then the header just slid right in. Mind you i had acess to a 4 post lift, hope this helps though.
Yea dude, when I went to 1-7/8 from 1-3/4 I had NO CLUE it would be that big of a deal!! If I had to re-do it I would sacrafice the 20-30rwhp and keep the 1-3/4 headers. The Kooks 1-7/8 are the biggest PITA EVER!!!
Get ready to unbolt the steering shaft, motor mount, mount pedastal, valve cover, oil filter, oil pressure plug, and power steering!!! ******* PITA!! I'd rather pull the whole motor and start over.
There's a little 1" square casting block on the corner of the block that sticks out. You can cut that off. Piece of cake with a cutoff wheel or sawzall. Removing that will give you a lot of clearance to maneuver the header into place. It's just ahead of the oil filter.
To get the 1 7/8 Kooks in my 2002 on the driver side I had to take the steering loose, remove the alternator to get to the motor mount, take the bolt out of the M/M and jack the enging up as high as I could get it. It was a painful process. There ain't no "sweet spot" to get them in w/o jacking up the motor.
I finally got it thanks guys Im still running the stock kmember I knotched it pretty good. cut a liine in the firewall took a hammer bashed it in. Cut the tab off the block and finally got them in there. Took it to the exhaust shop now i have to trip the pass side k member the header tube is hitting it.
will post up pics later. 8 hr job dam
Kleeborp the Moderator™
I just got done installing my Kooks 1-7/8" headers yesterday, and all I had to do on the driver's side was turn it 90* so the collector was facing down, push it up, and rotate it into place. The steering linkage was still in place, the oil filter, everything. If you use header studs like I did, you won't be able to install even one in the heads prior to putting it up in there (only applicable to the driver's side), but that is no big deal.
OK. So you're saying you didn't have the heads on your engine when you put the header in. That's a whole different deal man.
With my engine fully assembled and in the engine bay, my passenger side 1 7/8" Kooks slid right in w/o any cutting or adjustments. The driver side required removing the steering linkage, taking the alternator off, removing the bolt from the motor mount, and jacking the engine up as far as it would go. Also had to make a very small notch in the K-member.
