Help me identify this sound!!
what is that knocking sound?? bought the car less than a year ago and it didnt make that sound when i bought if i've only put about 3k miles on it... i did an oil change right after i got it and ever since then it has made the knocking sound... i used castrol syntec 5w40 the first time and it has penzoil platinum 10w30 in it now.... is this piston slap or what? thanks..
http://www.youtube.com/watch?v=PGbt12sYe5g
Could be a warped lifter. Like the previous poster depends where the noise is coming from. I thought I had a bad lifter but never honed in on it and it was the water pump
I have the same noise. Only I also have an exhaust leak, but I'm taking care of the pretty soon. Check for leaks, but alot of the LS1's have noisy valvetrains. But when you said that it appeared... Idk, rules out alot. But I wouldn't sweat it if it runs fine. I've had it forever and it sounds identical to yours.
yeah it seems to quieten down some after it warms up... but yeah it runs fine, doesnt seem to be effecting performance at all.. but idk
need better audio . pop the hood and get close to the heads. first one side then the other. try and narrow down drivers side or passenger side. Then narrow down top or bottom.
I had a vicious knock once, most thought it was a rod but it turned out to be the substrate in the hi flow cat had come apart and was raping and the sound was resonating through the pipes.
Pontiacerator
don't think it's an exhaust leak but i could be wrong... the main reason is because when i bought the car it did not make that noise... about three days after buying it i did an oil change and used castrol syntec 5w40 european blend and it has knocked ever since then
How many miles on the car? I've noticed more and more noise develop as my A4 car gets close to 80k. And my M6 car, which is at 84k, is just plain noisy.
Sounds just like my car, mine started doing it after I put RP in it all it is, is lifter tick mine has basically went away after I switched to a conventional oil GC 10-40.
But I would get a better video with the hood up and you revving as stated above.
I have the same noise. Always had since i bought my car. Thats 5 years later no problem. I think its slap, but you only notice it at idle. It doesnt go up with the revs though. I use Castrol 0w-30.
My 02 Formula has the EXACT same noise. I'm sure its a lifter or lifters. Mine also has terrible lifter noise at start up and after a restart hot for a few seconds. I have good oil pressure too, Always above 40 even at idle.
