High oil pressure readings
car is an 02' z28 M6, 50k miles give or take. Normally the oil pressure gauge reads 40psi at idle all the time and about 60psi at 3000rpms gettin on it. I installed a cheap *** catch can yesterday and drove the car for the first time today.
Today it Idled at 45psi on the dash gauge, 60psi at 2k rpms cruising, it was warmed up fully, isn't that a bit high?? then down the road getting onto the freeway the gauge hit 70-75psi@3k rpms+ driving sort of quick but not WOT or beating on it for 2-3 shift,
3-4 didn't drop the pressure for more than a split second, shift to 5th only dropped it to about 55-58psi cruising. I did NOT go over 65mph at all just to clarify OR take it over 4000rpm.
Kinda freaked me out as this was on the way to dinner, I went straight home without dinner and removed it straight to the trash. RPMspeed catch can setup already ordered.
>> idk if it matters but when removing the catchcan the inlet hose <to manifold>
was kinked up
Someone locally suggested that my sending unit is bad??
I have no error codes or ses lights showing.
Car is currently running a custom diablo performance tune if that matters, but that's been loaded for months.
I know the deal with diablo tuners so no need to remind me, it was a gift.
Knowledge/Help Would Be Greatly appreciated, Experienced guys please chime in!! Please; Asshats with nothing but sarcasm and negatives to say Please refrain from chiming in.
Thank you for your time.
Respectfully,
RiceEaterZ.
was kinked up
Respectfully,
RiceEaterZ.
Mine always runs high (02 camaro ss) 60 at idle 65-70 under load. My tuner tells me that the gauges are not to be trusted, as long as the pressure is going up as your RPM's increase, should be OK.
Has anyone ever ran rich after installing LS6 manifold and ported throttle body? My idle is fine but it is running rich when driving at a stop oil pressure is back to normal. Basically shoots from 40 at idle to 60 when pressing throttle.
Right but even when I take my foot off the throttle the oil pressure doesn't come down at all. It stays pinned at 60 until I come to a stop. Before install car never ran this rich. Could I have got a bad OSU?
u do realize that the terms "rich" and "lean" are associated with a/f and have absolutely no bearing on oil pressure/level etc. right? Anyway, i would just take it as an indication that u have a strong pump. If the OSU didnt work your gauge wouldnt move.
& to the OP - ive heard that different brand oil filters will create different oil pressure readings. Supposedly the K&N will flow a few more PSI - im gonna try it since mine is low. If i could have mine at 60 constant and 80 WOT id be happy.
ok cool thanks guys, you've helped me relax a bit. I didn't change anything on it other than the catch can install, I did try to take the pcv valve connection off the wrong side first? pump is stock with 53k miles on it, Oil filter hasnt been changed in 2.5k miles and i use Delco pf46's. Looking into an aftermarket oil gauge and I emailed my "installer" about it anyway, hes gonna be doing a cam soon with a ported ls6 pump and the supporting **** since I don't have time to learn & do it myself before the tuners come down.
anyone else think I should check the sender?
Thanks in advance just trying to learn and get answers.
Sorry for being such a newb regarding rich and lean. I was worried because before I installed the manifold after releasing the throttle the oil pressure would drop back down. Example it would read 40 rise to 60 with increase in throttle then when throttle was released would drop back down to 40. Now it rises to 60 with throttle increase and when the throttle is released it stays at 60.
Not that this pertains to oil pressure but I would get a tune if you have ported tb, ls6 intake manifold and longtubes if you want to correct things.
If anyone has anymore interest in this kind of stuff the forums over at http://www.bobistheoilguy.com are very helpful and informative.
