Which Edelbrock Manifold?
Old 07-30-2009, 11:34 PM
Fast 95 Z28's Avatar
Default Which Edelbrock Manifold?
Which Edelbrock intake manifold would be best for a stock LS1 with a MS3 cam? Specs on the cam are 237/242 .603/.609 112 Degree with a 2300rpm-6800rpm powerband. The high rise which is for 3500rpm-7500rpm or the low rise which is 1500rpm-6500. These are the carbureted style manifolds.
Thanks
Old 07-31-2009, 12:25 AM
has no one ever run this setup before?
Old 07-31-2009, 10:02 AM
1CAMWNDR's Avatar
I wouldn't use a Victor style intake untill you build a motor with big cubes. The single plane intakes like a cam with a lot of overlap. You will probably loose torque and power below 5,500 rpm and probably only make up 10 hp between 6,500 and 7,500 rpm.
