? about AIR/EGR and removal
On this 98 vette it comes out of the 2 header flanges thru check valves and into a Y then down to the pump then to the air lid.....Wouldnt this be the EGR system and not the A.I.R.? I thought the A.I.R. pumps air into the exhaust for the cats but theres no piping that go into the exhaust except the header flanges and they have check valves so it wouldnt be able to flow back in there....So I would call this the EGR? Exhaust gas recirculation, since thats what it does, No?
and if I took this system off on a car with 2 high flow cats would it hurt anything? (no piping to the mid pipe or anything)
thats the air pump equipment. the EGR is the tube on the top of the intake right after the throttle body. look at LS6 in take to see difference. check valves let air in and keep exhaust from coming out.
Yeah, I know its meant to help the cats but will it harm them if they never get fresh oxygen? and won't it affect the tune since when it turns on the pump it looks for different fuel trims via rear o2 sensor? and I would assume it would set a code? but just wondering if it can damage the cats since I see alot of cars dont run cats anyway
I think it only runs when the car is in open loop...as it'd seriously mess up the O2 sensor readings...when the car is cold and warming up, the pump is on helpng the cats start working, when it warms up enough for the O2 sensors to work in closed loop, the air pump also shuts off. I don't think you'll shorten their life removing it, it just makes the emissions take longer to clean up when you start the car up cold if it isn't there.
