Will the 85mm FTP lid fit under a SS hood?
I had the same issue, I bought the ftp ram ir kit and the 85mm lid which in fact is a 98mm lid after intalling everything the hood just would close..so I got so frutrated that I ended up buying a hood
I had the same issue...I bougth the FTR ram ir kit and the 85mm lid, which in fact is a 98mm lid and after I finish installing everything the hood just would close...so I got so frustrated that. I ended up buying. A hood
My TSP 85 mm lid doesn't rub at all but then again, I have a VFN 3'' SS hood so it could be for that reason. Perfect fit & immediately SOTP performance. My gas mileage also increased. I used to get 110 miles on half tank going 75 mph on cruise control. Now I hit 135 miles by half tank so it's a significant increase.
I would trim to much just trim it evenly a little bit and at the front part of the air box and then put it back on and check and see how it fits and then if you need to trim more then trim a little bit more. I know how you feel I'm on my second lid but my tuner trimmed mine and it doesn't rub at all. I don't know if they broke it the first time or I broke mine. Cause that lid and forcing it shut, something has to give at sometime. I think as said above he has an aftermarket hood that's why he has no problem.
Yeah, as a matter a fact, the improvement was over an aftermarket lid......It was after I swapped out a "Stealth Lid" that used the Corvette air filter. It was an old type of lid that no longer is in production & the snout on it was very oval & narrow. This was a HUGE improvement......Much happier now......
