Junk In My Radiator
Old 09-04-2009, 06:05 PM
bluebird71's Avatar
Default Junk In My Radiator
My car has been running hotter lately and getting upwards of 230º even with the 160º thermostat. I figured the thermo had just gone bad until I investigated further. I found that the coolant reservoir had a crack in the top of it, possible from the weight of the Optina battery, but what shocked me the most was when I pulled it off and dumped it out and what came out looked a lot like dog ****. I'm wondering what could have happened here and how serious this is. I'm going to go get it flushed out I guess, but will that be enough and is there more going on here than just the radiator. Here is what came out:
Old 09-04-2009, 06:40 PM
01ssreda4's Avatar
Holy Chit thats crazy...
Old 09-04-2009, 06:46 PM
bluebird71's Avatar
Motor still runs fine but I gotta figure out what this is. I was planning on doing my blower install next weekend too.
Old 09-04-2009, 06:51 PM
dilatedpeoples28's Avatar
wow, never seen anything like that lol
Old 09-04-2009, 07:12 PM
LS1 Tech Administrator
Patrick G's Avatar
Yuck. That's some nasty looking stuff. Glad you found the problem.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 09-04-2009, 08:16 PM
Soul TKR's Avatar
looks like typical effects from Dexcool crap... mine did the same thing for the longest time. I'd flush, put in fresh Dexcool, flush again, more Dexcool, etc... after a lot of research I ended up finding out that the Dexcool was the culprit. Put in some yellow/green Prestone extended life and haven't had a problem since. I check it often, and never get the "jelly" substance that I was getting from the Dexcool. That stuff is complete crap...
Old 09-04-2009, 08:31 PM
LS1crazy01's Avatar
X2 I kept getting some nasty gritty crap in my resivour and I would flush it and after a few days there would be more. I finally switched to some yellow stuff and its been clean for about 10 months now.
Old 09-05-2009, 09:41 AM
jam01's Avatar
the problem with dexcool is you are supposed to use distilled water. that nasty **** is what comes from tap water.
Old 09-05-2009, 09:48 AM
71-Camaro-98's Avatar
The first week I got my Camaro I had it flushed and only distilled water and Prestone have gone in it since. Never had a problem.
Old 09-05-2009, 11:46 AM
bluebird71's Avatar
Do you think this **** is clogged up in my thermo or will a flush clear all that out too?
Old 09-05-2009, 12:06 PM
badhoopty's Avatar
looks familiar... yesterday i managed to squeeze this out of my overflow tube while flushing my system due to a faulty power steering cooler. the stuff is so sticky that putting air to the tube wouldnt shoot it out.
http://pics.montypics.com/badhoopty/...6_img_4195.jpg
i too had a cracked overflow tank that i replaced about 3 years ago. i didnt notice any of this stuff in there, but then again i wasnt looking...
rest of my cooling system looks like its in very good shape besides being recently subjected to about 30 or so miles of power steering fluid contamination. i'm completely ocd when it comes to maintaining this car, and i know for a fact that in the 6 years i've had the car that no green stuff has been added and it has never been ran with low coolant.
i'm thinking its just typical dexcool voodoo from being exposed to air and constant wet/dry cycles in the overflow.
Old 09-05-2009, 02:06 PM
jam01's Avatar
i would flush it real good, or you could replace the radiator. just check the cooling fins inside and keep an eye on what comes out. exspensive but better than a new engine.
Old 09-05-2009, 06:43 PM
bluebird71's Avatar
So should I keep runing the Dexcool and mix it with distilled water or what?
Old 09-05-2009, 07:59 PM
jam01's Avatar
you can do that or flush and use the green stuff. they still recomend using distilled water with the green stuff. tapwater has too many impurities in it.
Old 09-05-2009, 08:04 PM
ADM
ADM's Avatar
I found this similar crap stuck to my radiator cap when I opened it a few weeks ago at the start of my cam swap. And this is a new radiator, hardly 1000 miles on it! I am flushing it and flushing the block as well.
Old 09-06-2009, 07:56 AM
DaddySS's Avatar
Flush it three times per the service guidelines - allow the thermostat to open each time then refill with dexcool and clean drinkable water. You do not need distilled water with dexcool, just clean water - I use bottled water in the gallon jugs.
Old 09-06-2009, 01:30 PM
bluebird71's Avatar
How many gallons do I need to get to put in there?
Old 09-06-2009, 06:25 PM
It is always a better thing to put Distilled water into a radiator no matter what coolant you are using. The reaction you worry about is between the radiator metals and the water, not the water and the coolant.
