Coupler Help needed (Fast Toys 98mm lid)
Old 09-19-2009, 02:28 PM
transam69230's Avatar
Default Coupler Help needed (Fast Toys 98mm lid)
I have a ws6 lower airbox and I am switching over to speed density tune, and I can't seem to find a coupler with the proper bend it to go from the lid to the tb. Right now i have a 4in coupler that is straight and is 6in long but it has kink in it. I have fast 92mm setup on the car so the inside diameter of the coupler needs to be at least 4in. What is everyone using, I have used the search button and I have also searched the web and have come up with nothing.
Old 09-19-2009, 03:11 PM
madball's Avatar
Did you try www.siliconeintakes.com
Old 09-19-2009, 04:37 PM
WS.666's Avatar
I used a 6" long straight 4" (diameter) silicone tube. It fit once, then when I took it off I couldn't get it to fit right again, so I cut the TB end at a slight angle and it fits perfectly.
TB: Holley 90mm
Lid: FTP 85mm
Old 09-19-2009, 06:32 PM
Moderator
98Aggie's Avatar
A silicone charge air cooler hose works great. Has good flexability and easy to trim to allow a better fit.
http://www.goodyearep.com/ProductsDetail.aspx?id=10422
Check your local semi-truck repair shop they usually have these in stock.
Old 09-20-2009, 10:49 AM
I got it to fit, thanks for some posts guys.
Quick Reply: Coupler Help needed (Fast Toys 98mm lid)
