BEST heads for ms4/fast90
Old 09-24-2009, 07:46 PM
LSXFORMULA99's Avatar
Default BEST heads for ms4/fast90
I was wandering what heads will work best with my fast 90 and ms4. I know they will all help alot, butwasnt sure if one works better than other.
Old 09-24-2009, 08:46 PM
TORCHD 02 TA's Avatar
If you're on a budget, I would go with a set of P&P 243 heads
Old 09-27-2009, 04:35 PM
yeah i was thinking of getting a set. those are fairly cheep. what kind of hp numbers would i be looking at
Old 09-28-2009, 10:04 AM
teke184's Avatar
budget...either a nice set of 5.3L heads or the 243s
non-budget...TFS 215s or AFR 205s
decent heads should yield 450rwhp no problem, better heads have showed upwards of 460-470rwhp.
Old 09-28-2009, 01:04 PM
c0ncEpT's Avatar
I would try some of those new TSP PRC215 heads. That combo seems to work well.
Old 09-28-2009, 09:36 PM
ryan@rpm's Avatar
That would be your best bet since they can be milled and you can bump your compression up quite a bit with the PRC 215's
Old 09-29-2009, 10:03 AM
thanks alot guys! i hope to have the ms4 and a set of heads on the car for next race season, it should pick up alot going from my tr224 cam
