EGR and Air block off plates
Will these work on stock manifolds if I ditch the EGR and AIR systems on my 00 WS6?
http://www.ws6project.com/user_stor/...oducts_id=2333
That is what I used to block mine off. I had the tuner tune out the codes it will throw. Once you remove all the piping, it makes working in the bay much easier. Good luck.
LSX Mechanic
Don't waste your money on block off plates unless you want the bling.
The intake can be blocked off with a rubber adjustible freeze plug that can be bought at any major parts store for about $5. A.I.R. tubes can be blocked off by simply threading a bolt slightly larger than the hole down into it. I use old pressure plate bolts for this, but if you have a stack of bolts laying around I'm sure you've got 2 that will fit.
