LQ9 Flywheel, Clutch, Pressure Plate
Old 11-24-2009, 09:33 PM
Shiny Red's Avatar
Default LQ9 Flywheel, Clutch, Pressure Plate
I need some help. I found a LQ9 from a 2004 Cadillac Escalade. It came with a flex plate. I want to convert it to use a t56 from a 2000 Camaro. Can I use a clutch, pressure plate and flywheel for 2000 Camaro for this set up? Would a flywheel, clutch and pressure plate from a 2010 Camaro work? I also need a pilot bearing. Thanks
Old 11-26-2009, 11:38 AM
Pharcyde50's Avatar
I know the 2000 setup will work.
Old 11-28-2009, 10:58 AM
Shiny Red's Avatar
Thanks, any manufacturer suggestions for a LQ9 with a Comp Thumper cam and a T56 and 4:11 gears?
Quick Reply: LQ9 Flywheel, Clutch, Pressure Plate
