Need to helicoil an alternator bolt
Old 12-02-2009, 05:41 AM
pHEnomIC's Avatar
Default Need to helicoil an alternator bolt
One of the alternator mounting bolts pulled the threads when i screwed it into the engine. I would like to properly fix this. Luckily there is a lot of access so it shouldnt be a problem.
Can someone tell me the exact size helicoil i need and what size drill bit/tap to use with it?
I would like to get it ordered so that next time im home I can fix it quickly.
Old 12-10-2009, 02:31 AM
pHEnomIC's Avatar
ttt please
Old 12-10-2009, 10:07 AM
Rubidon's Avatar
What size is the bolt?
Old 12-10-2009, 08:47 PM
tom falco's Avatar
Check the size of the bolt and go to the parts store and get a coil KIT. It comes with the tap and the coil and the size of the drill. I am lucky one of my customers works for heli coil and he is a camaro GUY. So the access to master kits is endless. Master kits also have the drill bits in the kits. Hope this helps TOM
Old 12-10-2009, 09:36 PM
pHEnomIC's Avatar
Anyone know what size the bolt for the alternator might be my chance?
Old 12-11-2009, 10:17 AM
88SS LS1's Avatar
It is either 10-1.5 or a 8-1.25 bolt there is only one smaller bolt out of the 5
Quick Reply: Need to helicoil an alternator bolt
