Verifying a header's primary diameter
Hey guys, a couple of months ago i bought a beautiful used set of what i was told were Kooks 1 3/4" race style LT's (non stepped).
The passenger side install was a breeze and the driver side was a real bitch. (I had thought that Kook's design was to be real easy on both sides...and this wasn't my first set of headers to install, either)
Last night a few of the guys and i were talking at Bob's big boy and joked that maybe the headers were tougher to get in since the primaries were bigger. (the difference from 1 3/4" to 1 7/8th's isn't too drastic so I doubted it)
Then one guy (hitmanws7) looked on Kook's website and said kooks didn't make a 1 3/4 "race style' (no AIR provisions). We then went and looked at our cars. I think they looked similar to my friends 1 3/4" Hookers, but he swears mine look bigger. This all sparked the debate....how do we measure the diameter of a primary? Is it the I.D. of the primary or the O.D.?
I figured I could wrap a shoe lace around the primary, mark it and then measure it for the size, but I dont know what the O.D. should be.
Anyone out there got an idea? Maybe some sponsers who sell them?
Thanks for any help.
x2^^^ inside diameter. Different vendors use diffferent size tubing thickness so i doubt you can figure it out that way.. I know how... remove the DRIVER side header and check the inside diameter..lol!
Jk... I had problems installing my kooks but after they slipped in they had great overall clearance and mine are 1 7/8.
I believe that larger header diameter headers would be harder to install, atleast in my z06. These 1 3/4 ARHs were an extremely tight fit on the driver side from the top. Would have had to jack the car up higher ( no lift ) to get it in from the bottom if they were even a hair larger.
Kleeborp the Moderator™
Mine wouldn't go in from the top... but close. They had to go in from the bottom. We had to disconnect the steering knuckle, bang the firewall, and the heat shield, remove the oil filter, and notch the K.....all for a set of friggin headers. And now I'm gonna be pissed if I've got 1 7/8th, lol.
https://ls1tech.com/forums/11596564-post4.html
I should really put this somewhere that people can easily find it
What can I do to sweet talk you into measuring the O.D. of one of your primaries?
I'll check back later today...if you don't have an answer by then, I'll see what I can do. For right now, the car is put up for the winter, so it is under a cover right now. I might be able to get a measurement from the bottom though since it is up in the air. Just kinda hard for me to do while I'm at work
LS1Tech Premium Sponsor
I've always seen and measured header primaries by their outside diameter. I've verified this on pretty much every LSx header manufacturer including Kooks.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I've got the same headers, Kooks 1 3/4" race style no EGR no AIR. I measured mine before I put them on, inside to inside was 1 3/4". Maybe you could measure the circumference, mine were 5 9/16".
Also my driver side install was a Pain, I had to take off the oil filter and finagle the header around until it slipped in (from the bottom).
Also my driver side install was a pain, I had to take off the oil filter and finagle the header around until it slipped in (from the bottom).
On 1 3/4" that'd come to about 1.75", for 1 7/8" it's 1.875".
__________________
