SLP MAF Question
Old 01-21-2010, 03:10 PM
Doobie52's Avatar
Default SLP MAF Question
So, I've got a FAST 92 setup and I'm in the process of changing the rest of the intake track; Fast Toys 98mm lid and a MAF sensor. I have a few questions about the SLP MAF because I've seen negative posts about it on here. It it just a GM 85mm MAF? Does it contain the IAT, and if so can I buy the conversion harness? Why the bad feelings about the SLP one and can anyone recommend a better MAF? I have ported ends on my stock MAF, so should I just keep it? Any help would be greatly appreciated.
Old 01-21-2010, 03:22 PM
somws6bird's Avatar
Depending on how radical your setup is I would stick with the stock maf.
A descent amount of people go with the slp, there's nothing wrong with it.
I will be changing my stock maf and lid for 100m TSP with a FTP 104mm lid
Figure anything making over 450rwhp will benifit from a bigger maf.
Old 01-21-2010, 03:25 PM
Doobie52's Avatar
Thanks for the info. Does the SLP have the IAT incorporated into it?
Old 01-22-2010, 01:15 PM
Doobie52's Avatar
Anyone? Is the SLP MAF just a Delphi unit that SLP sells and does it include the IAT built it?
Old 01-22-2010, 01:20 PM
Squirts11's Avatar
Just call SLP...their contact info is on their website.
Old 01-22-2010, 02:44 PM
hitmanws6's Avatar
the SLP MAF is a 85MM Delphi MAF with a resistor built into it so the MAF readings are as if you still had the stock MAF on
