Helicoil came out of oil drain plug hole
Old 03-16-2010, 01:39 PM
UCABlackChevy's Avatar
Default Helicoil came out of oil drain plug hole
I was changing my oil this weekend and when I tightened down the bolt it seemed like it stripped out. So I pulled the bolt back out and the first ring of the helicoil came out with it. I pulled the rest of the coil out with the bolt when I tried again.
My question is can I buy the same size helicoil (12 X 1.75) and put it in? Will I have to redrill and retap the hole or can I just install then new one without all that?
Old 03-16-2010, 04:15 PM
1gt2nv's Avatar
You can buy a new plug at most auto parts stores. Is the plug bad or the oil pan?
Old 03-16-2010, 04:23 PM
It's the oil pan, not the bolt.
Old 03-16-2010, 04:42 PM
1gt2nv's Avatar
Oh. Well that really sucks. Try to retap it yet?
Old 03-17-2010, 04:56 PM
Haven't tried, the header is in the way. I'm going to try a new helicoil then I'm going to try a self-tapping oversized drain plug. If that doesn't work then the car goes into my parent's backyard barn and I'll buy a truck.
Quick Reply: Helicoil came out of oil drain plug hole
