Voltage maxing on car
Old 04-04-2010, 05:53 PM
ABeasst's Avatar
Default Voltage maxing on car
After a tuning session I was on the way home and got on it. As I started to slow down I looked at the gauges and the voltage gauge was maxed and many of the warning lights were lit up like Air bag light, abs light, etc. I got back to the house and then went out of town. When I just got back tonight I tried to start the car to see if maybe the alternator had gotten hot and the car was completely dead.
I hooked up the jump box and fired up the car and the voltage gauge once again maxed so I cut it off.
What could be causing this? Electrical short maybe?
Old 04-04-2010, 07:11 PM
memphis24's Avatar
check to see what the alt is putting out. should be close to 13ish volts. the voltage reg could be bad.
Old 04-05-2010, 06:20 AM
toadzq8's Avatar
Internal reg is messed up on your alt. Put a meter on the output and check it.
Old 04-05-2010, 09:20 AM
ramair21's Avatar
Old 04-05-2010, 10:31 PM
memphis24's Avatar
what he said
Old 04-06-2010, 12:31 AM
Soul TKR's Avatar
I agree with the above... however, have you washed your engine bay lately? I got a puddle of water that accumulated where my power plugs into my altenator after washing the engine bay. It did exactly what you are talking about. I got an air compressor, cleaned out the puddle of water in the socket and it fixed the problem...
