Newbie help
Newbie help
Howdy, I put an LS1 in my 61 Impala and I am now getting around to hooking all the harness wires up. I have an after market harness. The first picture shows a little female connector, of which I have no idea what connects to it??? I have no extra wires (excpet for my o2 wires) I've attached a couple of pics. The first pic has a red arrow pointing to the unit.
What am I missing? Thanks in advance!!!!
oh oh, me thinks me in trouble. I have no extra wire to connect to it. I ran the engine in the frame before I put the body on it, and it ran fine. The computer was tuned for my application, does that make a difference?
The first one is the oil pressure sending unit. The map is a smaller one with an angle 3 pin connector plugs into a gromet into the back of the intake.
This is a MAP sensor...
THIS is the oil pressure unit, yes it is fragile.
Excellent, thanks. The MAP sensor is connected. According to my wiring guy, I don't use the stock oil pressure sensor. That's why the engine ran with no problems without the oil sensor being connected. I have to drill and tap a hole somewhere near the oil filter to use after market gauges.
Thanks for the help!!!!
