New FAST 102 w/78mm tb
Old 04-21-2010, 09:34 AM
THE LAST Z's Avatar
Question New FAST 102 w/78mm tb
Do you think I would loose any power this way? A FAST 102/102tb -vs- FAST 102/78mm tb? Some say the TB size doesent matter...
Old 04-21-2010, 09:53 AM
MonmouthCtyLS7's Avatar
Yea man you'll be suffocating that thing...get atleast a 90mm or above. After spending that on an intake i wouldnt try to save a dime on the TB. Think about where the air goes through before it gets to the intake, ofcourse it matters.
Old 04-21-2010, 10:05 AM
blazerls1's Avatar
also, the mounting areas are totally different between the two.
Old 04-21-2010, 10:49 AM
Jon@Texas-Speed's Avatar
I believe the 78mm TB is a 3 bolts setup and the FAST 102mm intake will be a 4-bolt design.
Jon
Old 04-21-2010, 12:11 PM
Yea I wasnt sure if the fast 78 mm tb was a 3 or 4...like i said man your probably going to have to go to the 4 bolt 90mm or above.
Old 04-21-2010, 12:21 PM
Justus67's Avatar
Yep, you'll choke it like it owes you money. 90mm+ on tb size for sure.
Old 04-26-2010, 11:15 PM
THE LAST Z's Avatar
Will a 90/92 mount on it?
Old 04-26-2010, 11:17 PM
Dewman's Avatar
yes they will
Old 04-26-2010, 11:21 PM
THE LAST Z's Avatar
Cool. Do you think a slp bellows will fit on a 90/92 TB? I dont want to end up changing everything...
