Throttle body question
Old 04-25-2010, 07:09 PM
trans_am_2000's Avatar
Default Throttle body question
so i bought a throttle body a while back and i forget what year it was off of, its ported polished,bump stop removed ,half shaft, so when i put it on it gives me car a hanging rev when i rev it and it idles at 2 grand, and i see people saying that 98-99 are different throttle bodys and im wondering if that may be whats wrong as i have a 2000 trans am, is there any way to tell what year its for? thanks
Old 04-26-2010, 11:25 AM
redbird555's Avatar
the spring on the 00-02 is blue and the 98-99 is brown
Old 04-26-2010, 12:55 PM
Undertow74's Avatar
sounds like the blade is partially stuck open. hard to tell without actually seeing it. Could be wrong TB, or could be slightly over ported...or you may have to adjust the linkage on it cable may be to tight leaving it slightly open..
hope you can figure it out! good luck
Old 04-26-2010, 01:14 PM
01 ss vert's Avatar
All good advice! Take the bellow off and manually open it with your hand with the car off and see if it sticks or not. The spring color you can see just by opening the hood.
Old 04-26-2010, 01:27 PM
01'SSLSX's Avatar
Old 04-26-2010, 01:48 PM
BriancWS6's Avatar
The difference is the throttle cam. It is designed to open faster on the earlier yrs. It will not give you the issues you are seeing.
